i placed the motor in the car, yesterday. I want to work out any problems I might have before getting the car painted. I discovered the extra width of the 5.4 puts the valve cover edge very close to the inner stud from the master cylinder. I am considering shortening the stud or I might try an allen headed bolt and finding a way to mount a nut in the adapter plate. I am also considering using a file and elongating 3 holes so that I could rotate the whole assembly away from the motor. I would like to try and make this as accessible for repairs as possible. Any thoughts are appreciated.
I will be using a ranger master cylinder, so there won't be any interference with the lines and the motor.
Here's the stud hitting valve cover. The engine was not even sitting level. It was tilted forward
I knocked the stud out to see what kind of clearance I would have.
The answer is not a lot!
