CCRM deleting
SW
Hi all
Does anyone know if it is possible to suppress CCRM ??
My complete harness comes from The Detail Zone, and PCM has benn tuned to suppress management of cooling fan and fuel pump...
I did not find any information about in elsewhere
regards
Nicolas
Nicolas,
Make sure we are talking about the same thing..:) Cooling Fan/Constant Control Relay Module (CCRM). Next why would you want to Suppress the CCRM? If I am not mistaken all it is a relay inside of it. Are you having issues with your cooling fan?
[quote author=SW link=topic=127.msg241#msg241 date=1236682386]
Hi all
regards
Nicolas
[/quote]
SW
I thought with computer tuned not to manage cooling fan, i did not need CCRM... that was appropriate to me because i do not have CCRM at home (relay for cooling fan is obviously in CCRM if I am not mistaken)
But i had a look to the DTZ datasheet and I saw i'll need CCRM... (there is the harness with specified plug)... so i just have to buy one... :-\
[quote author=SW link=topic=127.msg247#msg247 date=1236773273]
[/quote]
I see post pics and keep us posted.. Looking to getting the The Detail Zone harness this week.
myers407
Old post but to help clear the air about the CCRM it does control the fan but also many more items on the car. Anyone wou has messed with the old EFI Fox will find the EEC relay under the dash but the Mod cars have none. This is one of the five that has been moved to the CCRM. It will also control the A/C the fuel pump and a few of the heave amp draw body functions. Hope that this helps.
d90212
i removed my ccrm....tied it into the factory relay and supplied power/solder the neccessary wires that needed to be connected....used a high amperage relay for the fan....
main reason i removed it....CCRMs crap out...its only a matter of time when theyll be obsolete...and they cost more than a conventional relay....
d90212
heres a sample page...basically just follow your wiring diagram book for the donor harness and the wiring diagram of the fox your installing it into...
looking at the wiring...pin 24 12 17 needs power in the start or run position
