whats a trw rack?Yes, as long as it's not a trw rack, found that out the hard way just make sure you get new Teflon seals that go on the fittings.
ahhhh thanks...definetly dont have that 1This is what a trw rack looks like, i believe they were included in the trw handling package of the earlier years View attachment 2397
i used the stock fox rack with my build, even used the pressure line, re-bent some of it with tubing bender and installed in to hydrobooster and it worked! looks factory too.
I have the mach 1 rack and hydroboost installed. You need to cut the rod end but that about it. Best thing is there is not "wreeeeeee" power steering pump sound like the fox has.
I have a fox rack on my hydoboost setup. The noise he is referring to comes from the stock type fox power steering pump. Which is caused by lack of maintenance. Mine is noise free.You can use the inner and outer tie rod ends from fox on the later racks and it should work perfectly, that's how mine are set up. The later racks are supposed to be better, but he's referring to the noise they make when you turn with the fox racks. The cobra racks apparently have better feedback, but I couldn't really tell you a difference, we have a cobra.
