Just in case anyone is wondering how to install the front seatbelts of a sn95 into a foxbody, this is how I did it. The seatbelts only work at a very specific angle range and will lock up if tilted too far in any direction. I used washers to space the seatbelt outwards and give it a closer to 90 degree angle and used a longer seatbelt bolt that we had, I believe some from the fox would work, moving the bottom towards the interior of the car. From there I tilted it slightly towards the front of the car until it was centered from locking in each direction and the seatbelt was centered coming out of the reel. I then welded a small tab on the side of it where the stock fox tabs would go for easy installation if they are taken out, and so they don't move as they lock up with use.
